The pump for the forward head on our Hunter 45 CC, will run, but it will not drain the toilet bowl. Any suggestions?
Jeff
Hunter 45 CC,
Jeff
Hunter 45 CC,
Yes. The make of the head and what you've done so far to determine the cause of the problem.Any suggestions?
Hi Peggie. The clogged tank vent is mentioned in the linked article in my reply to the OP. That was the culprit in our case. Unsure about the OP issue; too little information to make any kind of recommendation other than possibilities. Nice to hear from you. Hope all is well with you and your family. Getting pumped (no pun intended) over the coming season. And you?You forgot to mention a blocked tank vent that's pressurized the system, Terry
That is one reason why I asked whether the pump empties the bowl full of water.One other possibility: a failed discharge impeller caused by running dry.
Did you read my article in the earlier post? If you remove the cap on your deck pump out fitting, does the bowl empty when you flush? Is your holding tank empty or full? Just ruling out various causes. If the bowl does not empty by trying the above then likely time to check the impeller as Peggie suggests.No the pump does not empty the bowl full of water.
