Head Bolt Backing
Oct 28, 2019
46
Hunter 38 North Shore of Boston
I’m replacing the jabsco manual toilet with a Raritan marine elegance on my hunter 38. I just completed removing the old head and noticed that the lags used to mount it came out with black on the threads for a good portion of the bolt. Is there plywood underneath the head platform fiberglass that these bolts go into? Im concerned if there is that it may be rotting and in need of replacement. I’d really love to avoid cutting the fiberglass head module if I don’t need to.
Dec 2, 1997
9,008
- - LIttle Rock
If the lag bolts long enough to extend beyond the flooring, it's possible that portion is black due to corrosion or just mold/mildew. Are the bolts entirely black or only the lower part of them?
--Peggie
Oct 28, 2019
46
Only the lower portion of them. I’ll be back at the boat this evening and can measure how much clean thread there was.
My boat is a 2006 hunter 38- would it be likely hunter used plywood blocking under the toilet or a solid fiberglass surface? I supposed I could also see if I can get a small pick into the bolt holes and see if the surrounding material is soft.
Oct 28, 2019
46
Looks like there was about 3/8” of clean thread before the black in the lags. I didn’t have anything on hand to look at the holes in too much detail but I did find a good access under the head module. I’ll be back there with a boroscope to take a better look this weekend and confirm what’s under the fiberglass.
Oct 17, 2021
46
Hunter 410 Boot Key
There is plywood in at least the forward head on my H410. I replaced the lag screws with expansion anchors
senang
Oct 21, 2009
316
hunter 38 Monaco
On our Hunter 38 I have found only glassed in aluminium backing plates. I think the black coloration is an indication of SS in an aluminium plate. Screwing the fine thread of a bolt in wood seems like crimal irresponsability to me.
