Peggie - I have an '04 Hunter 33, with the standard Jabsco manual head. I too am having a back-up into the bowl, and can't pump bowl contents all the way through. BTW, fresh water flushing, no solids ever in this system, and we spare the squares - only the smallest piece of paper to do the job.As I've seen in many posts, I checked the vent line - it doesn't seem to be blocked, but...the boat has those stainless steel flush-mounted vents, rather than the clam-shell vents - I can't get inside it to check for blockage, but I don't know what could get inside that thing anyway. I got the vent hose off the inside of the hull vent fitting, but couldn't get it off the tank side for fear of breaking the plastic tank vent fitting. Nothing noted inside the hull side of the hose, except the lovely aroma.In Raysco's thread dated 6/29, you suggest replacing the joker valve. I may try this, rather than the whole rebuild kit. You also suggest replacing the Jabsco with a better manual head. What's out there that will fit what looks like 4 floor bolts and 4 total hoses of the Jabsco?Thanks,Gregg
