If the water is clean...
That is, you're sure it's flush water, and not waste back up...it very well could be that your problem is simply water outside the boat seeking its own level inside the boat (rising through the head intake). A vented loop would solve the problem. However the vented loop MUST go between the pump and the bowl...if you put it between the intake thru-hull and the pump, it'll interfere with the toilet's ability to prime and can "fry" the intake impeller. The only toilet Groco makes is the Model K, which is about $800...they did make the model EB (discontinued), but it's about $500... and since it's unlikely that anyone would have spent that much, I suspect what you REALLY have started life as a Groco Headmate (manual) that a previous owner converted to electric with a Jabsco conversion kit. Check the Jabsco website (http://www.jabsco.com) to see if their conversion kit looks like your toilet. If it's not, check it against the Groco toilets at http://www.groco.comOnce you know what your toilet really is, you can get a manual for it and find out also find out whether it's adequate wired...'cuz as I mentioned in a previous reply, 99% of slugglish flush problems are due to low voltage. That can be due to a failing battery, the wrong wire size (wire size is determined by the round trip distance from the battery, not just one way), corrosion at the connections, Meanwhile, check your holding tank vent to make sure it's open--that your problem isn't a pressurized that's backing up. The first place to look is the vent thru-hull...that's where most blockages occur--this time of year, it's often a dirt dauber nest. Otoh, if you've opened the deckfill and didn't get a spew, that answers the question: the vent isn't blocked. If you haven't, I don't recommend doing so until you ARE sure the vent is open.Bottom line is, there are a number of possibilities--from blocked tank vent to low voltage to water rising in the intake. You're just gonna have to eliminate the possibilities till you find what IS causing it. Except for the tank vent, you'll need the owners manual--or at least the electrical specs and and exploded drawing--to find what IS causing the problem, and then cure it without causing new problems. Till you do find it and fix it, keep the intake seacock closed except when the toilet's in use. Don't restrict the water flow in during flush or try to flush without bringing in any water, 'cuz that can fry the intake impeller.
