After reading the glowing results of the now famous Maine Sail System of treating a boat's hull I took the plunge but am having some problems with execution.
The boat is only lightly oxidized so I went straight to the polishing procedure.
I bought a variable speed buffer and I`m using the 3M yellow buffer pad and 3M Finese It II.
Temp. has been on the cold side (low 40s one day & mid 50s another day)
As per the instructions I cleaned the hull first. apply the product to the pad, spray a bit of water on pad, start slowly move up in speed for 45 seconds in a 2x2 area.
The resulting haze is a pig to buff off by hand with the micro fiber rag. I found if I spritze with water it smears and then buffs off better but it seems to take a long time.
I have spent about 9 hours over 2 days and have only done the transom & one side.
There must be a step I`m missing...any recomendations would be appreciated.
