Ron Thweatt
I have restored 28 sail boats had 6 new ones what is wrong with this picture. I have my 3rd Oday 25 this one is a 1978 with an omc has any one had any problem with these,mine will start every time, runs great but seems to miss at high rpm the old internial tank has been removed and i am now using a port plastic 6 gal tank any one see any problems, I need a stearn rail my boat has lift lines and a bowpulpit but none of the stearn,the roller fuller works great, the center board is down and the rope to pull it up is broken I guess i just pull out and reconnect any ideas? I found that the original blower for removing fumes would not work while checking the wires found about 5# of dirt dobber nest Have pick up a new plastic blower should last longer and will put some screen over the vent.Also would like to put a dodger on any one done this and have you seen any problem with this also need a measurment for a bimini would like to move the attachment for the travler at the boom about 18 inches toward the mast so i can use a longer bimini. this boat does not have the pull out bed on the port side any idea how to fix this...I am going to sell this boat but if it does not sell "HOPE NOT" then will keep and fix up i am 53 and past all the other boats i also have just for fun that is what i told my wife a skippers mate i am fixxxxing up in the drive way any one need let me know thanks for all replies
