You will need a Truck
I did have someone tell me the Jeep six cylinder if properly outfitted with Mopar high performance parts would tow that, but I think it would be pretty hard on the vehicle. I feel for ya' though. I don't especially like trucks either since they're strictly work vehicles, regardless of the leather seats, and are essentially useless if you don't have any other need for them, not to mention expensive to run and license. But for my O'25, I didn't feel there was a choice. I bought a 1/2 ton Ram with a 360 and it pulls great, as does a Chevy 350. DO NOT USE A CHEVY 305 (or whatever that small engine is for them). I've pulled with that and it's terrible. The Ford with the Mustang engine isn't to bad, but I still would want something larger. I think the 350-360 C.I. range (depending on manufacturer of course) is what you will need. I've used all of these because I used to rent the truck before I bought one. Renting was to much of a hassle for me because of where I had to rent the truck and then tow the boat. It ended up being a 400 mile trip. But if you have a U-Haul dealer in the area that rents pickups, that'll work for launching and hauling.If you're a trailor sailor, I really would be nervous about pulling that boat with ANY six cylinder. You probably should bite the bullet rather than risking premature failure of the Jeep.P.S. I think the Dodge Dakota and Durango are available with the 360. I know the Dakota can pull that much with the right engine and axle combination, so the Durango should handle it also.Russ
