I cruised for 3.5 years without a windless and only got wore out lifting the chain in Cartagena, Colombia in the 45' deep water. Once I decided I was crossing the South Pacific I knew I had to get one due to the 70'+ anchorages. I installed a new Lewmar with remote. So far I have hardly used the remote but rarely do I pick up the anchor with the wind blowing more than 10 knots in the anchorage. When I have used it, it was great to motor forward and operate the windlass from the cockpit. It can be done with another switch there and my windlass came with that switch, but I have yet to install it due to having the remote. Less wires to have to deal with.
In the past, I used to motor up a little then run up and pull the chain in quickly by hand, then repeat process. Worked in windy conditions but the more the wind, the more times I had to do it.
Now that I have the new windlass, I love it. I find myself picking up my anchor and improving my anchor spot a lot more...aka...anchoring isn't nearly as difficult these days. I also installed a wash down hose up there too and love that.
As a previous poster said, and it works in light to med winds, pull up the slack in the chain and wash down while doing so, then stop and let the chain weight pull the boat forward and repeat. This is the reason why I find myself not using the remote much as a single handler but it's good to know I got it when I need it.
Note: the remote has a delay, so the windlass will run about a second or two longer than you pushing the button so be careful.
