Hauling 310 wing keel
cam
Oct 5, 2014
34
catalina 310 perth
I am due to haul my 310 winged keel for annual maintenance for the first time under my ownership. Is the strength of the hull such that the yacht can rest on the keel or should it be suspended in straps with the keel off the ground? Any feed back would be welcome. Thank you. Cam
KZW
May 17, 2014
831
Catalina 310 #307 Bluewater Bay, FL
When they hauled mine at Barber Marina for the survey, they let it hang in the straps. A month later they hauled it to paint the bottom. The hull was on jack stands with boards under the keel to spread the load.
Dec 16, 2011
261
Catalina 310 Atlantic Highlands
I just hauled mine out. The harbor puts blocks under the keel and then jack stands all around (see photo).
2,441
Catalina 310 Hingham, MA
Just make sure they place the straps in the correct place. We got a bent stanchion that I had to rebed and should probably replace thanks to a misplaced strap.
Sep 29, 2008
1,980
Catalina 310 #185 Quantico
Designed for it
The boat is designed to rest on the keel, the stands are only for keeping the boat from toppling over. Make sure your stands are placed correctly so you don't get deflections in the hull.
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
I have found on my C310 that the stands are best placed where the sling marks are for the fore and mid stands, and one foot forward of the aft cleats for the aft stands. This is in addition to the bow stand, of course. The hull is structurally supported in these areas, whereas the hull is subject to "oil-canning" if the stands are placed randomly. I have found this out the hard way, although the hull suffered no permanent damage. As stated previously, the weight of the boat is supported by the keel, and the stands are only snugged up to the hull, to keep it upright. Don't forget to run a chain from each stand to it's counterpart on the other side of the hull, to keep the stands from sliding out of place. In addition, my boat is placed on loose gravel over dirt, so the stands are mounted on plywood, and checked for snugness several times during the winter, since the stands will settle, and could become loose.
