John Baumgartner
I just bought the boat,while it was sitting in my driveway in the rain, water would apear below decks. The water was comming from the molding supporting the Lexan hatch cover. Since the Lexan hatch slides on this molding and it is not a water tight slide, water was dripping on the underside of the Lexan. I figured that their has to be a way to correct this problem, here is what I came up with. I went to the local Lowes and bought felt strips 1/4 inch wide and about 4 feet long roll, it comes with one side of the felt sticky with the paper that you strip off. I attached the felt strip all the way around the molding that the Lexan rides on, including the part under the fiberglass hatch. Now not only is it not leaking anymore but the Lexan slides so much better. Just thought you might like to know, and I would be interested in replies from the forum about this solution. While I was at it I also added a oak center brace below decks on the Lexan for added support (I noticed the "Not a step" sticker)
