hatch
John
My forward hatch is in good shape (Bomar replace about 6 years ago) but the plexyglass is cracked. Has anyone just replace the plexyglass.
A
Alex Mazurek
Bomar plexyglass
I just replaced the plexyglass on my front hatch this past weekend. It was not too hard of a job. Call Bomar and order the plexyglass, glasing compound and rubber seal. You should be able to the get the serial number and model number off your current hatch. The numbers are in between the hindges when you open the hatch up. All you do is cut the old plexyglass out and clean the edge of the hatch, put the new rubber seal and apply the glaze Set the new plexyglass in and add more glaze to fill in the seams. The only drawback it that it takes 2 days to cure. Good luck, e-mail me back if you need Bomar's number of if you have any more questions about the hatch.
