4200 - 5200 roger right
I agree with Roger, hatches have caused vessels to meet Davy Jones more than once before.If putting together something that you do NOT want coming apart (worry about taking it apart when that day come...if ever) and not to leak, thru-hull fittings, mast compression posts, Sheer deck to hull, hatches, housings, and ANY permanent fixture use 4200 (quick dry) or 5200 permanent sealent.I used it in betwixt my mast partner/wedges, then ended up having to pull the darn mast twice after that.Yes, it was tough to get the 5200 out, drilling, pulling with channel-locks like taffy, but happy to do so. Each time I put 5200 back in, gobs of it! I was happy that the partners had NOT wiggled free like what happened on the passage to Hawaii (no sealent in the partners) when I nearly lost one mast.I know many are squeemish on this 5200 thing, but you folks stay in safe harbors, and live in a perfect world.Picture yourself in a full-fledged STORM with a huge sea a runnin?If you hadn't sealed with the very best, I Guarantee you that you would be regretting it!
