After three "professional repairs" for leaking decided to fix it myself - this is the bomar hatch just forward of the mast, marked 200 229323. Sent a note to try to find replacement and replacement parts to this site
Here are the questions
a) Picture 2 - the interior liner is so separated from the hole - anything I can should do about that or just caulk the heck out of it. Picture 3 shows close up
b) Picture 3 - look in the far left corner - the deck where the frame meets up is wildly uneven, looks like some idiot to a dremel or power tool to it. Shoudl I try to get some gelcoat or resin (or even fiberglass putty and try to level out those low spots/indents) to try to create a better seal ? or as above, just caulk the heck out of it ?
c) What caulk do you use ? 4000 or 4200 ?
d) Finally Picture 1 - looks like some type of split, maybe even weld on the aluminum frame ? Its so precise, wonder if it was there originally as part of the design. Get a new frame if I can find it, get a welder, or just caulk the heck out of it ?
And yes - I cleaned off all that old caulk with acetone....
Suggestions much appreciated on even finding the replacement hatch
