Hatch Gaskets
JORGE FIFE
Does anyone know where I can gt the gaskets for the 2 hatches on a Hunter 33, 1982?
When I phoned in, I was asked to check numbers on the hatches: I can see no numbers, other than the name: Bomar
These hatches have 2 kind of cogs that you turn in into 2 grooves on the base, where you tighten it
Please help
Thank you
Nov 16, 2009
1
Cal 9.2M Watkins Glen NY
I had leaks thruout the boat and ordered new gaskets for all my portlights and hatches for a 336 thru HunterOwners. The portlights were Gray replacement seals. That went smooth. The hatch seals I received were all incorrect even though I did extensive research and sent detail pics:cussing:. Bottom line: I found the integrity of cabin roof to the inner shell liner was breached on all of the hatches. Water was flowing all over the place. Hard to find where they really were leaking. I pulled each hatch and found that all of them required epoxy repairs. I used Interlux bedding compound to seal them. This stopped all the leaks and I never replaced the window seals. This was time consuming but my wife is really happy! :) Good luck to you.
