Hatch cover repairs
Pearson 26W Marblehead
Before I bought the boat someone replaced 4 out of 6 bolts holding the hatch cover hardware
with steel. Needless to say they are completely rusted and have to be replaced. I don`t think I can hacksaw the nuts off without damaging the hatch cover because the rusted up nuts are sitting flush to the top of the hatch cover. I suppose I could drill down through the
top of the bolts as a last resort. Anyone have any Ideas on an easier way to get these rusted up bolts off. I would like to avoid damaging the hatch cover top.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
if you can post a pic it would help a lot
regards
woody
Jun 21, 2007
2,118
Presuming that the nuts are too far gone for liquid wrench type products to work (and/or there is a risk that the solvent might damage lexan/plexiglass), I've found that cut-off wheel attachments for Dremels can often help in these sort of situations. Use the cut-off wheel to "split through" the nut. Several thoughts -
- Cut-off wheels often fracture and pieces will go flying --- so protective eyewear is a must -- also keep spectators away;
- The Dremel will need to be held with two hands so that it can't slip away onto parts of the hatch you don't want deeply scratched
- The process will heat up the metal and maybe damage surrounding plastic? Possibly work for a short time on each nut in sequence to let the work cool.
Just an idea.
Mar 13, 2009
158
irwin 37 (73-74) grand harbor marina
sounds like a novel idea to me. surround the area with wet cloths. and remember the sparks will contain ferrite and rust specks may appear if not cleaned quickly. jimbob
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Center punch the bolt and drill it out .Will take enough material to snap off excess .
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Another vote for drilling out the rusty bolts. If access is good enough, you could also try using a cut-off wheel or grinder wheel from the back (Adult size preferred over a Dremel ;) )
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
I've done this many times, but with a 'baby' sized dremel :)
Use a small metal cutting disc and cut the nut in in half across it's top. You don't need to go all the way through, just enough so you can break the nut off the bolt. It's a 2 minute job, tops, and I find it much easier than trying to drill them out.
Cheers,
Brad
Mar 9, 2009
2
2 34 on the hard in Ms
If the nuts are accesable a dremil tool with a carbide cutting wheel will do the job, 2nd option a nut splitter if there is enough room and it fits over the nut.
