Mast Steping
Stu,It is quiet easy to step your mast while on the water or the trailer. O'Day has a system that is well documented for stepping the mast forward. The system I use involves 2 sections of 1" electrical conduit, joined at one end with a bolt (but not very tight), place some rubber caps on the other ends and place one end just forward of each chainplate on the deck. Next, attach a block to your stem fitting and run a line from a winch, forward through the block and attach to the bolt on the gin pole, (the electrical conduit). Disconnect the forstay and attach this to the gin pole bolt. Now you are ready to lower the mast to the rear using the winch to take the friction on the line to control the drop. Keeping everyone weight as centered as possible, have some stand in the rear of the boat on top of the seats to take the mast as it gets to the bottom. Here is a photo of a Catalina 25 performing this operation in his slip. I did it with my OD 26 last week.Ben AllenMontgomery, AL"Wahoo"OD 26
