Has anyone changed the bulbs in the control panal
Jeff
I have two lights on the control panal for my 3GM30F which do not light up when I turn the ignition switch on. I have attempted to remove the bulbs from their recepticles to inspect them, but so far have not been able to accomplish. They appear to be housed in a black rubber sleeve, and I don't know whether these are a push fit, or a twist fit (bayonet type) as is shown in the parts cataloge. I'm a little afraid I will break them while trying to remove them from the recepticle. I purchased replacement bulbs from my Yanmar dealer, but they sold me a 3 watt bayonet bulb, which does not look like the bulb that I have. Mine look like they might be straight sided all glass. when looking at the control panal, they are the two bulbs on the left side of the bank of four. Are these oil pressure, temp or what? Any suggestions?? Or a part number ?? thanks, Jeff
May 6, 2004
916
Hunter 37C Seattle
Jeff, is there a togle switch
on the panel. If so I think it is a 3 position switch, off, test, and night light. Test position should turn all good bulbs on.
jeff
Yes, Scott there is...thanks
I'll give that a try, but if they are burnt out I'm still wondering if they are a push fit or twist.
