Has anyone capsized an H23?
Steve
Has anyone capsized an H23? If so, what were the circumstances? How did you recover?
Terry
I'LL BE SURPRISED IF YOU GET ANY ...
responses. This is a rare instance. Terry
Terry
A KNOCK DOWN IS MORE COMMON THAN A ...
capsize, but still rare. Any sail boat caught in the right conditions can be knocked down or capsized. I think your boat has 800 pounds of ballast, which helps keep it upright in most all conditions. You want to avoid taking larger waves abeam, which increases the chance of a knock down or capsize. Purchase a Chapmans book on boating from most any marine store. Very good reference source for general safe boating information. Good luck. Terry
K
Kevin
No but ...
No but I have put the leeward window in the same horizontal plane as the water. Not quite a knockdown because the water was still beneath the window (port). By letting out the mainsheet, I de-powered the main to reduce the heel angle and just kept going. There was no point in using the rudder to head up into the wind---another way to de-power the sails---because it too was horizontal.
