I have the same thing.. Harkin still sells the pin replacement kit. The adhesive is Locktite Red, their permanent adhesive. What I found is that if your forestay sag gets excessive, the foil will work the pins out as it spins and flexes from turning around a catenary instead of a straight line.. Yes, I have thought of replacing the pins with nuts/bolts but haven’t been vexed enough yet to tackle it.. I didn’t think of tapping the internal foil connector and using a screw on each side, that may be a viable thing to do. I suspect that the same flexing that is working out the pins might do a fatigue failure on the screw threads ?? I am thinking that my slowly degrading mast support is the culprit, allowing the headstay to sag more than it should. Good luck with ‘em,
