Harken MKII (or MKIII) furler foil connector repair
rakos
Feb 25, 2018
5
CAL 25 NSC
This item (Westmarine Model # 345017 | Mfg # 810 ) needs to be replaced. It is the lowest one. The easiest way would be to remove the furler spool unit and thread the connector up about 2ft. The connector has about a 1/4 hole drilled through it so the forestay wire has to be threaded through it. My question is what is at the bottom of the forestay: is it a Sta-lok which can be removed so that I can thread the wire through the connector? Can the furler spool be slid off in one piece or do I have to disassemble it? Thanks.
May 25, 2004
443
Catalina 400 mkII Harbor
when the transport damaged mine on my previous boat, 1984 hunter 34, the fore stay had to be replaced.
the pieces were installed then swaged.
good luck
mike
