Pitted balls?
I'd be surprised to hear that the balls are actually pitted - have you actually inspected them?They do require periodic maintenance. Harken recommends frequent washing with fresh water and i've found that it also helps to periodically spray the track car's track and bearings with a dry lube e.g., McLube or something similar. If they are binding it is also more likely that they are twisting on you which can happen when the sail shape is not uniform as you raise or lower the sail off the wind. If you can rule out dirt and twist, be careful removing the cars for a closer inspection unless you still have the car carrier which came with the set - unless you enjoy the sound of ball bearings falling all over the deck.If they are actually pitted, I'd check with Harken before proceeding further in the event they may be more gratuitous with you then they were with my problem of the cars falling off.DonIllusionDonillusion
