Aha...
The wet/dry valve has failed...it's a VERY common problem with Jabsco toilets. The valve hangs, partially closing off the intake, preventing the toilet from bringing in any water and creating back-pressure. The cure: replace the wet/dry valve. While you have it apart is a good time to lubricate the toilet. Buy a tube of Super-Lube (same thick teflon grease that was in it when it left the factory). Put a healthy squirt in the pump, pump a few times to spread it all over the inside of the cylinder. Not only will your toilet need no further lubrication for a full season, but by doing it now, the grease protects the rubber parts in the toilet from drying out over the winter. You'll be good to go next spring.
