Hard to find stainless machine screws
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
I need some #10 machine screws 4.5 inches long.
I also need #8 machine screws 5 inches long
This site does not have them, and I have not been able to find any site that has them.
Anyone know of a vendor that would carry such a screw?
Jul 21, 2013
333
Searching for 1st sailing boat 27-28, 34-36 Channel Islands, Marina Del Rey
Try McMaster, excellent site with specifications.
Get the 316 stainless steel screws.
Nov 6, 2006
10,250
Mighty long.. ya might have to go with "all thread" threaded rod, and nuts/washers on both ends.. a fastener specialty place like Fastenall (as Topcat says) .. Ace Hardware might be able to special order them for you too..
Jan 6, 2010
1,519
See if there is a commercial bolt & nut store near you & ask if the have 316 s.s.
Every Waste Marine store should have these in stock however, I believe they carry 304 s.s. mostly but, my store also has some 316s.s.
CR
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Good suggestions from others. Add to that list suppliers like Hamilton Marine or Jamestown Distributing. They are located in the Northeast.
I have no affiliation with either of them but they carry a lot of supplies for builders and commercial fishermen.
caguy
Sep 22, 2006
4,004
What do you need such long screws for? Can you use threaded stock with nuts.
Give these guys a call.
Allen Bolt & Industrial Supply
1711 W Burbank Blvd, Burbank, CA
(818) 840-8080
Sep 8, 2014
2,551
West Marine is the HIGHEST retail mark up on hardware, never buy there unless its an emergency and you are just grabbing one or two in a pinch.
McMaster Carr is great for hard-to find and specialty fasteners. The website is great with detailed specs, drawings, and the best search and sort features of any website. I.e., you can sort by material so select stainless steel right off the top, then your screw size, thread pitch, etc and end up with exactly what you need. Only draw back on McMaster, a bit on the higher end of price, but I shop there frequently because of the above noted reasons.
http://www.allensfasteners.com/ This site is more geared toward automotive, but they have the best prices on ARP 12 Point Stainless Bolts, "I put that $hit on Everything!"
They also have excellent prices, fast shipping, and great assortment of bolts. When I needed 7/16 x 6 inch stainless to fix my outboard bracket, this is where I got em.
Fastenal is also pretty great, good website with excellent search criteria kind of like McMaster Carr, but they don't have the measured drawings. So far this only place I can fairly reasonable prices on Bronze hardware, also one of few places I could find external tooth lock washers made of Bronze! Prices are mostly fair to fairly good if you order large quantities.
Here is thing about the particular screws you are asking about, #8 @ 5 inches and #10 @ 4.5 inches... Not trying to be a jerk but that is just nuts. The reason they don't make such skinny machine screws to that length is that the fastener won't be able to handle the torsional stress over such a long shaft, even minor torque will break it.
You didn't mention pan head or flat-head, but they do have #10's in flat head only @ 4, 5, and 6 inches. #8's I cannot find over 4 inches of any type.
You also don't mention your application. Sometimes you need to modify your plan or fastener schedule... If it's possible to over bore you should up-grade to 1/4" or possibly even 5/16". Also, as others mentioned you might be far better off using threaded rod with cap nuts, would be cheaper that way too.
Sep 23, 2009
1,480
I have found that Bolt Depot.com is the easiest and fastest source for fasteners. Mcmaster carr is great for everything else.
Boltdepot has saved my bacon often as most hardware does not come with the required bolts.
