Hard to believe
209
Hunter 34 Forked River, NJ
A new boater in our marina has been adding Muratic Acid to his holding tank all season, both after a pumpout, and between weeks if he didn't pump before he left the prior sunday. What can he do to clean the acid out and freshen the tank to allow the Odorlos or other deodorants to work? That is if he didn't eat the bottom of the tank by using the acid!
Dec 2, 1997
9,010
- - LIttle Rock
Not the worst thing he could have done...
In fact, muriatic acid is commonly used to dissolve sea water mineral buildup in hoses and is even what Raritan's instructions for cleaning a Lectra/San calls for. So it's unlikely that the tank or anything else in the system has been harmed by it. However, it's not a "deodorizer" and it doesn't do much to dissolve sludge in the bottom of a holding tank either, if that's what your new boater has been trying to accomplish. All he needs to do to flush out the tank is the same process to flush any tank chemical out: fill the tank with water via the deck pumpout fitting (NOT through the toilet)....pump it out. Put about 5-6 gallons more water into the tank via the deck pump out fitting...pump that out. Repeat till the water being pumped out is clean. You might also recommend my book to him. :)
Ross
Jun 15, 2004
14,693
I don't think that there is too much risk
of ruining the tank muratic acid is sold in plastic bottles.
Ross
Jun 15, 2004
14,693
Steve, Aluminum is quite resistant to acids but
very quickly attacked by bases like sodium hydroxide.
V
Vic Willman
Muriatic Acid
Peggie's right; not only isn't muriatic acid not a deodorizer, the smell of muriatic acid mixed together with holding tank contents is enough to gag a maggot! Be sure to refill the tank with clean water and pump that out, too. I'd do it 2 or 3 times before putting the holding tank back in use again. Then re-charge the tank with Odorlos, KO, or whatever additive he's using, and start using it again.
