Inflatable with HP floor
AndyWe just bought a used inflatable with a high presssure floor and a 5HP motor, and for the kind of use you're talking about I believe that type of setup might work well for you too.The HP floor makes it very easy to stow when not in use, which for us is a majority of the time. If you are going to keep it inflated all the time (on davits for example) or a majority of the time, then a rigid floor is better, but of course you lose the stowable factor. I think floorboards are a pain in the butt, again depending on how frequently you will have to stow the dinghy.The inflatable is the best for tending though, simply because they are very stable, and you can bump them into your boat without worrying about damage or breakage. We had a small rowing dinghy that was fiberglass, and it was great for rowing, but not so hot as a tender due to instability when getting in and out of it at anchor or on a mooring.How's that for a start to this thread?Ron VanderveerMelbourne, FL
