kepeters and foresails
KP,
I am a Sunday afternoon sailer...
I like things simple and easy.
However, after years of roller furling, I am just learning things.
Sail Shape - study the topic in detail before you make change. Sail shape determines a lot and roller furling does not mean that you have best use of sail from 0 to 130, 150 or what ever.
Also, although you have to talk to the experts, understand that furling does not mean you can reef your 150 furling genoa to a storm sail. What leaving a small section exposed apparently allows the sail to become partially blown thus rendering the whole sail inefficient. This is according to a retired North sailmaker who took time to expain fabric to me.
Now I have done that a whole lot, but I usually do not fret about sail shape. My sails are probably blown or otherwise misshapen. But they move my boat and that is all I ask.
So study the topic before you do anything. Consider the cost as to whether it is of value to you. Different furling devices do different things. CDI is usually the least expensive, and it works for it intended use.
Harken is worth the money if you want one of the best, but it can cost almost twice as much. With Harken you can fly two foresails wing on wing. It is ball bearing movement so under all conditions should turn more freely. Also it turns freely on top which in theory should put less stress on forestay.
And it allows easier change of foresails. Yes, people with roller furling do change foresails too.
And there is much more to learn about different equipment.
Ed K
26
Addendum:
"Remember, not all crazy folks are locked up! Some own boats!"
Hi Rich,
I use the original Neil Pryde hank on headsails, a working jib (100%?) and a 150% genoa. I have been wondering about the pros and cons of roller furling, since I often sail alone or with inexperienced crew. It is common where I sail for the breeze to build throughout the day. I will often start with the 150 in the morning, then have to change to the working jib by mid-day, then back to the genoa in late afternoon. Sometimes I stay with a certain sail combination longer than I should, because I am too lazy to make the sail change. This often happens as the breeze builds, so I am overpowered, heeling excessively, etc. On a recent cruise it occurred to me that I would save myself a lot of work and perhaps be able to match my headsail to the conditions better with roller furling. Those are the pros that I can think of. What are the cons?
KP
