Hanging a Hammock
111
Macgreggor/Balboa 26 25/26 Baraga
How strong do we think the bow rail is. I am thinking of running a line from
the top of the mast to the bow rail and hanging a hammock on it from the mast to the line I run down. Do you think that Bow rail should be able to hold 250 pounds of weight or would you rig something else...i just wanna use my hammock on my boat
Jul 28, 2010
914
Boston Whaler Montauk New Orleans
Have you ever leaned on or sat on your bow rail? That would be a good indication. Also, the bow rail is only going to be subject to about half the weight in the hammock. How are the rail supports situated?
May 4, 2005
4,062
front stay, and mast.
a stock mac bow rail, good luck with that.... its too low anyway. right?
Ross
Jun 15, 2004
14,693
The strain that a hammock applies to the ends varies as to the straight line distance between the supports and the vertical displacement of the center of the hammock. Stretch a light line from one point to the other and put a fish weight scale on the end of the line and then a five pound weight in the middle. Then multiply by fifty for your 250 body in the hammock.
caguy
Sep 22, 2006
4,004
Listen to Ross, its all in the vectors Victor (Airplane). I've copied others and hung it from the Mast on one end and the Main or Jib halyard on the other end. Support the main halyard/hammock connection with a loop around the forstay. If you have a furler I would use a wide strap to distribute the weight on the furled sail. I was 210 at the time and it worked well.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Tie a bowline around your bow stay and attach the other end to the hammock. Then connect your jib halyard to the bowline and pull the hammock up to the desired height. Do the same on the mast end using the main halyard. The weight will be on your halyards not something like the bow pulpit that isn't really made to support that weight.
Ross
Jun 15, 2004
14,693
It is not the weight that you must be concerned about, It is the horizontal pull on the ends of the hammock.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
I tried going from the mast (spinnaker pole ring) to the forestay, but found that it was about 2 feet too short by the time you raised it enough to clear the deck and lifelines (you'd swing into them). So I attach the pole now and hang the ends of the hammock to the ends of the pole with carabineers, and attach the pole to the mast ring and the spin halyard to the forward end to hold it up. quick lashing around the pole to the forestay stops you from swinging in the wind. used it many times that way.
Jun 27, 2011
111
You need a bigger boat. ;)
I keep trying to tell my wife that. Okay so that was my original idea too was to go from the mast to the jib rolling furler but was worried about damaging the furler. Also this is for my second sailboat the Balboa 26 so it is a little bit beefier.
caguy
Sep 22, 2006
4,004
Don't hang it from the furler, attach it to the jib halyard and only use the furler/forestay to keep it extended. Use a wide strap or anything else to destribute load. I have seen may boat in Catalina set up this way, mine included.
Apr 8, 2010
1,606
Yeah, but my current budget won't allow for it, hopefully in a couple of years. Anyone own/manage, or have friends who does own/manage a business with 10-25+ computers that wants world class IT support and/or offsite backup and disaster recovery services? Every referral puts me closer to that bigger boat. :)
