Have an old SH HX260 handheld VHF.
Works good. Battery good.
The battery is a 7.2V 750mAh NiCad. However, the supplied AC charger is rated at 10v.
I never had the factory 12v lighter plug (CLA) for this radio, but awhile back I found a 90's cell phone car-cord in my closet with the correct output plug for the VHF. It's pass-through 12v, but I figured it's close enough to 10v.
It worked. I've used it once, to charge for about 30 minutes. Mostly just to test it.
Although I'm thinking if the boat battery charger is on, or solar or engine running, it's getting more like 13.6+ volts, which is nearly double the radio's battery voltage.
So my questions are:
Is there an operating range for this radio?
Am I damaging the radio or battery with the increased voltage?
Why is the radio battery 7.2v but the factory AC charger puts out 10v?
I'm looking at getting a selectable-voltage buck-down DC to DC converter, but the regulated voltage selections are 3, 5, 6, 7.5, 9, and 12v. Can I charge the radio's 7.2v battery with 9v, even though the AC charger is 10v?
