D dominick . Oct 16, 2005 2 - - santa barbara Oct 16, 2005 #1 is there a reducer between the hand crank and the crankshaft
Larry Wilson . Nov 23, 2004 281 Columbia 8.7 Super wide body Deltaville(Richmond)VA Oct 17, 2005 #2 re:hand crank don't (sic) fit. Never seen a reducer. It may be that someone changed out the fitting on the end of the shaft. Larry Wilson
D dominick . Oct 16, 2005 2 - - santa barbara Nov 17, 2005 #3 thank you mr. Wilson guess ill pull that big alloy cover and see whats goung on with the shaft end"fitting"?
