Hampton Roads Info
154
Catalina 310 Virginia Beach, VA
Ahoy fellow skippers!
There is a VERY strong likely-hood I will be relocated to Virginia Beach/Hampton Roads area. I have a Catalina 310 with a 6'3" draft. Any and all advice/input/tips welcome. Good sailing area (Chesapeake Bay WOW!), recommendations on good marina, living conditions etc. Thanks for the help!
Skipper Ken
S/V Juliet
Catalina 310 Hull #282
Jun 19, 2004
512
Catalina 387 Hull # 24 Port Charlotte, Florida
Hello Ken: Welcome to Tidewater if it happens. I'm up on the York River (second one up) so am not as familiar as I should be with the Marinas down around VB. Right next to the Chesapeake Bay Bridge Tunnel where the Naval Amphib Base is located is a cluster of marinas, that are protected somewhat. This is in the Pretty Lake area, really easy to get in and out of without tidal restrictions. I don't know of any that are south of the Bridge Tunnel other than a couple at Rudi Inlet, but the bridge restriction is a problem, and this dumps right into the ocean.
If you are going to be in VB the area next to the amphib base may be your best bet. There are a couple located at Willoby Spit, right next to the Hampton Roads Bridge Tunnel, and there is one located at Ft Monroe, as well as the marinas downtown Hampton. Further up the Hampton Harbour at Portsmouth is Tidewater Marina. Just above Ft Monroe is Buckroe and there is Salt Ponds Marina. All these are at the bottom of the bay so to speak. You will enjoy Mobjack Bay, with the East, North, Severn and Ware Rivers for nice weekend runs with pristine anchorages.
There are so many places to go on the Chesapeake, it may use up a good portion of your lifetime. Eastern Shore has lots of nice spots to visit as well as Tangier Island, Tangier Sound and points north. You will find that time will be your biggest constraint as it can get away from you quickly. We can go out and gobble up a week before we realize it is gone.
Look us up if you make the transition.
Tom
Jun 2, 2004
5,802
Not sure if there is another name but around Little Creek are several large marinas. Well protected, right near Shore Drive(Rt. 60). I lived in Virginia Beach when I was stationed at Oceana in the early 60's. I probably wouldn't recognize it today. I am very envious.
Apr 22, 2001
497
Hunter 420 Norfolk, VA
Hampton Roads
Skipper Ken
S/V Juliet
Hi Ken,
I've been home ported in Little Creek for many years.
When you are ready to make the move, PM me.
Tell me where you will be living/working and I'll help you as much as I can w/ marinas, etc.
Buck
