Iridium Caveats and more Ham/SSB
In my work, we communicate with lots of boats, using lots of different means of communication. Iridium freguently becomes quite garbled, although Globalstar always sounds like it is right next door. Iridium also often has troubles when used below decks.I am a great believer in the advantages of each system, but prefer Ham/SSB, myself. The ham requirements have been made pretty easy, these days. Yes, SSB radios do require a license, although the operator doesn't. There are radios type-rated for both SSB and Ham, and some have dials so that you don't need to enter frequencies from memory. Furuno makes a very nice one, for instance. The FCC can frequently tell if you are illegally using a Ham radio in place of an SSB. It is easy to be a bit off-frequency on a Ham radio. The FCC does check...I was once cited for not giving my call sign at the end of a lengthy SSB conversation and I have known others to have their knuckles rapped. Finally, your H37 has an external lead keel, I believe, which makes a great ground plane. Find a way to run three to four inch copper foil from the tuner to a keelbolt, and you have done the most complex part of the installation. The backstay antenna is easily done, and if you are more budget minded, you can substitute high voltage wire for the core of braided line. The outside of the line that covers the wire, insulates the antenna from being accidentally touched, and the line can be easily run from the masthead to the stern, bypassing the backstay altogether. Friends in NZ have an antenna like this, and we can communicate just fine. By all means, use an automatic tuner. Others have spoken of the great advantages of Ham/SSB. You can also use it for email. Good Luck.
