HAM Licenses
Rick D
Jun 14, 2008
7,206
Understand the new no-code license is a hot number. Also think I know that lots (most?) Mexico cruisers do HAM instead of SSB since HAM sets convert to dual SSB and HAM. Correct? Anyway, anyone know a handy site for self-study information? I have all the grounding, isolated backstay, etc., so I should do it since it's all the hard part... Rick
G
Guest
HAM in Mexico
Rick, My understanding is that Mexico allows high frequency usage for amateur radio operators from the US with only the technician license. This involves taking one test about basic radio theory and FCC regulations. The "high frequencies" (HF) range is from about 2000 cycles per second (hz) to about 28000 hz. The range is actually broader, but this is where most longer-distance radio communications occurs. In fact, most maritime radio traffic is between 7000hz and 14400 hz for voice and email communications. However, use of these frequencies without a higher level of license is legal ONLY IN Mexico. It is not legal from US waters. In order to be legal in the US or international waters, you need a general class license, which involves the technician test plus being able to read morse code at 5 words per minute. After listening to a morse transmission, you are asked 10 questions, 7 of which you have to answer correctly. "HAM" radios and "SSB" radios both transmit on a single side band (SSB) on HF. HAM radios are made to transmit on specific frequency bands that are licensed for amateur radio usage. The frequency bands that are licensed for SSB (commercial station) usage are separate from the HAM bands. Most HAM radios can be converted to transmit on SSB frequencies (channels) through electronic surgery. The simplicity or complexity of this operation depends upon the specific radio that's being used. But, from a strict legal standpoint, HAM radios are not "type accepted" for use on the commercial channels. As such, FCC fines are a possibility if a HAM radio is being used that cannot function within the limits imposed upon SSB radios. If modified to transmit on the amateur bands, an SSB radio can be used legally on these frequencies. All of the possible questions that can be asked on the exams are included in a pool. This pool and other info on the subject are available at http://www.arrl.org And for those thinking about a cruise to the Bahamas sometime soon, the Batelco (Bahamian phone company) tower in Staniel Cay has apparently fallen down. This has caused a total phone blackout to all of the southern Bahamian islands. So HF radio communication is the only way in or out. Those Pocketmail email devices need a landline to connect to the company's email servers. Good Luck. Robert Pancza
K
ken.shubert
Ham Help
There is a wealth of information available from the American Radio Relay League, the largest ham radio organization in the US. The web-site is: http://www.arrl.org Self study materials are available as well as help from clubs in every major city and most smaller ones. Amateur radios are not type accepted to the same standards as marine radios and may not be acceptable for serious passage-making sailing, even though they cover the right frequencies and will do the job. Don't get in trouble with the Coast Guard and/or your insurance company over this point. Many HF SSB Marine radios do cover all the Ham bands, however and that would keep you legal but at a higher cost. De... K0KS S/V Wouff Hong
Ron
Almost correct
Have been a Ham for 21 years. To obtain a General Class license you must pass a Tech witten exam as well as a General written exam and the 5 wpm code test. Learning code is like learning another language only not as difficult. There are only 42 character to learn and speed is just a matter of practice. If you plan to get a ham ticket don't short change yourself by stopping at a Tech ticket. Code or CW will get through when SSB (marine or ham) won't. There are hundreds of CW nets that will bend over backward to get your message through. And for days when propogation is good for SSB the "Maritime Mobile Services Net" will get you patched through to nearly any place in the country (usually). Just to give an example; last year I built a CW radio from a $100 kit. It puts out a mere 2.5 watts and still I get out all over the country. Sooooo, get the general class ticket. You won't be sorry. Ron
Rick D
Jun 14, 2008
7,206
Thanks Bob, Ken & Ron re: HAM info
I'm going to look into the self study option. RD
