Rope a dope
Yes they need to be replaced. The diamiter of the rope is larger than the wire. The sheves can be bought from Catalina direct at www.catalinadirect.com for about 13$. I just changed mine and replaced a cracked mast head as well. The sheves are held on with two pins and cotter keys. I had my mast down and it made all the work easy. Mast up should be a chalenge as you would need one line to haul someone up with and a second as a safty line. If you drop the mast you can replace all the pld wiring and lights at the same time. I did and also did the rigging at the same time.
