Halyards
542
Hunter 33 Seabrooke, Houston
Tomorrow I am finally preparing everything (halayards, spreaders, lights, etc) so that Tuesday the mast will finally go up
What size should I look for?
7/16 has been recommended, but 5/16 also
What do owners of H33 ('82) recommend?
Thanks
Dec 2, 1999
15,184
Jorge: Check the mfg recommendation for the sizes that should be used. You will also need to consider the OEM sizes. We have had some issues with halyard swelling when they absorbed moisture. I would think that 7/16" would be appropriate for a main halyard assuming you are NOT using the hi-tech stuff.
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
Either size would likely do the job well. I like a larger size that is easier on the hands. But, that is just a personnel preference.
Jun 21, 2007
2,117
One factor for your decision is that rope technology has come a long way since our Cherubini's were built. For a given diameter, even for the basic yacht quality line (like sta-set), stretch and breaking strength is now much better than it used to be. The Hunter rigging sheet that came with the my 1980 H36 when it was new (the PO's managed to keep it in the documentation!) specifies 1/2 - 9/16" for the mainsheet halyard. When I replaced mine a few years ago, West Marine had a too-good-to-miss closeout on a hi-tech vectran/polyester type line. At 3/8" it had less stretch and higher breaking strength than (say) sta-set at 1/2". So you might give consideration that there's no need to maintain the original 1982 manufacturer's recommendation. Instead you could look to a manufacturer's recommendation for a 2009 cruising boat with about the same height mast.
Larger diameter does lend a bit more grip when hand pulling, which as Paul F commented some find to be easier on the hands. But hoisting is usually only a once a day event for a mainsail.
Does the halyard on your boat lead to a self-tailing winch? If so, 5/16" might be too small for the jaws to grip well . Or if its a small ST winch, anything bigger than about 7/16" might be too large.
One advantage of the smaller diameter that I found is less resisistance as the rope bends around the sheeves and blocks. With the 3/8" halyard, I now have no trouble hoisting my mainsail all the way up by hand, whereas it was an effort with the old stiff larger diameter previous line. I wish I had known about the easier bending characteristics when I replaced my mainsheet line. It had been 1/2" which also was a struggle to fit into the jaws of the mainsheet dedicated ST winch. (I still don't understand how the previous owners managed.) I replaced with 7/16". I think that the smaller 3/8" diameter would have resulted in a smoother pull through the 6:1 purchase blocks + 2 routing blocks that mainsheet feeds through on its way back to the cockpit. I have no trouble with the feel of the the 3/8" for my halyard and I think it would feel ok also for the continously used mainsheet. Next time, I'll move down to 3/8" for the mainsheet .... just too bad that my 7/16" still has quite a fews years of good life left.
Jun 25, 2009
542
I think the general consensus is 7/16, and I take note of Rardi H36.
Thanks once again for taking the trouble to respond, I need every bit of help I can get
Jorge Fife
