sorry to post this twice, last one was a continuation of an earlier posted thread (about mast light wiring,) on this rainy, humid, no wind, thunderstorm day i had planned to be sailing. confined to my desk chair instead, where the radar shows 75 miles of thunderstorms to the west i have ordered new halyards to reach the cockpit on a hunter 23, 1988, an important project since I sail singlehanded frequently on a gusty lake where the wind changes directions and speed, unannounced, frequently. 1. to reinforce the cabin celing where i will locate the winch and cleats i am thinking of building a 1/2 inch or so teak or mahogany plate , probably 4 inches x 8 inches to accommodate cleats and winch in one plate, and recessing holes for the bolts and nuts to avoid hitting exposed bolts with my noggin, cabin celing is carpeted, the other option i considered would be to have someone build a stainless steel plate 1/4 or 3/8 thick and thread it to accept the bolts? both the cost and the necessary precision of threaded hole locations, as well as the depth of the bolts,seems problematic. 2. assume i should do the same where i locate the block to run the halyards through about a foot to the starboard of the mast step? do i need this much reinforcement or will large washers with some sort of a cap on the nuts and bolts be sufficient? 3. can i take the existing winch off the mast and re use it on the cabin roof? 4. when i do this should i rig a downhaul as well and if so for the jib as well as the main? would appreciate suggestions as to the size of the plates or other thoughts. i have not yet ordered the cleats or the winch or the eyelets through which i will run the halyards. jim
