Halyard replacement
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Can anyone confirm is the sheaves on the 9.2 are rope friendly? Currently mine are of the wire/rope spliced variety and I need to replace them. I have replaced a rope one before, and wire/rope should be the same from a replacement perspective. My spin halyard broke inside the mast and it was all rope so I think I am okay. I bought line to replace it but now I may use it for my jib halyard as it is pretty dry.
Sep 6, 2011
435
I believe the spliced wire/rope use a different sheave in general. I had to replace mine on a different boat but similar vintage. (Bristol)
I'd get a pair of binoculars or a camera with a good zoom and ask your local rigger.
SC
Mar 14, 2007
88
S2 9.2A Seattle, WA
You may need to replace the sheaves because rope is a larger diameter (but you knew that). If you do replace them contact;
Zepherwerks in Port Townsend, WA
edloouchard@gmail.com
360-385-2720
I have had him make sheaves for my S2 traveler and and for an Islander masthead sheaves. Good quality and fast.
BobM
Jun 10, 2004
3,269
According to Rigrite Kenyon sheaves are made for both. I will give all rope a try.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
i used the original ones that were for rope/wire halyards...all i did was re bush them with the bronze bearings....they work fine...mind you i am using dynema ??? spelling???? core
Jan 25, 2011
2,437
S2 11.0A Anacortes, WA
I replaced my wire/rope halyards with sta-set. Works fine. When I had the mast down two yrs ago. I looked at the sheaves and pulled some rope through them. Both myself and rigger thought it would be fine
Styx
Sep 6, 2011
98
S2 8.0C Erie
Zepherwerks
I used Zepherwerks. Awesome person to work with. Did a great job for my S2 8.0c.
jguyer
Sep 16, 2010
41
S2 8.5 Milwaukee
Great thread!! I am planning wire /rope halyard and had the same queshtion . I am planning on replacing my halyard with dynema. However I think the sheave bearring needs to replaced. Im taking the mast down soon and take a closer look. Thanks again for the info.
