Halyard help
John
What is the best solution for running halyards to the cockpit when there is truly no room to make the turn back with cheek blocks. (In other words the top hatch rail extends to the edge of the cabin top leaving absolutely no room for the block)
Russ Marcks
Running halyards
I'm not familiar with the O222. However, based on your description, the only thing I can thing of is to mount teh cheek blocks on a teak pad to raise the block above the handrails. Russ
dave
halyards
the boat and cabin top were not designed for that. it can be done but only if you have to singlehand the boat and it is a little messy looking
