So, the specs out of the manual on my H49 call for 170 ft of 9/16" line for my main sheet. I got the boat last year, and have struggled with two things with the main sheet from the beginning. First off is the diameter. I know that my main sheet is far from new, but it does still appear serviceable. The issue is that it hangs in the clutches, almost as if it's oversized. Now, measuring true diameter on an older line can be a bit of a challenge, so not sure if I just have a "fuzzy" 9/16" line or a 5/8" line - regardless, I'd like to look at going to a 1/2" line and was wondering if anyone had done similar. Next issue is the length. Now, I haven't measured the line yet that is installed, but it is WAY to long. I understand that it's set up to be adjustable from helm or from the cabin top, but I probably have at least 30-50' feet of extra coiled up at the end that I have yet to touch in the last 2 summers.
All of that said, looking at going to possibly 130-150' of 1/2" as an offseason upgrade for next year, but wanted to gather some insight/knowledge.
Thanks -
TJ
Thanks -
TJ
