H460 Washer Dryer
Apr 16, 2014
3
Hunter 460 Kodiak, AK
I currently have a 2000 H460 with the three cabin layout and I am trying to convert to two cabin with the workshop and washer/dryer. My issue is how the heck do you get the washer/dryer into that port cabin? If you have a cabin with washer/dryer combo what model do you have and how wide is you cabin door? I can see in the owners manual where it is suppose to go but all the washer/dryer combos that I see are requiring 22 inched of clearance.
Mikem
Dec 20, 2009
823
Hunter 466 Bremerton
A good friend of mine had a 2001 460 with the washer dryer in the port cabin. You are right about the dimensions of the door and washer. The opening to the port cabin was enlarged above the sink counter to allow the washer to fit through the opening. Once the washer was installed the opening was restored to the original dimensions.
I think the washer was a “Splendide” model made in Italy. I had one in an RV. The brushes in the motor had to be replaced but it was not too hard to rotate the unit in order to replace the brushes. With that experience in mind I did not install one in my 2003 H466. There would not be enough room to repair in place.
On a final note when my friend’s boat sold the unit was removed and much rot was found in the cabinet due to an undetected leak from the back of the unit.
The unit would be a great asset in port as long as no repairs are required.
Likes: hosemandc
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
...............how the heck do you get the washer/dryer into that port cabin?............what model do you have?
Ditto Mikem...........As far as model Splendide wd2100xc combo with vented dryer (see link below). This is choice for rver's who want a combo vs. side by side. Be sure to install a pan underneath and a vent. I installed 3 non-vented Splendide washer/dryer combos, one on a large motor yacht and in 2 apartments in the UK but fortunately access was not an issue unlike your sailboat. Good luck!!
Likes: hosemandc
Jun 1, 2009
1,837
Hunter 49 toronto
Dittom Mike...........As far as model Splendide wd2100xc combo with vented dryer (see link below). This is choice for rver's who want a combo vs. side by side. Be sure to install a pan underneath and a vent. I installed 3 non-vented Splendide washer/dryer combos, one on a large motor yacht and in 2 apartments in the UK but fortunately access was not an issue unlike your sailboat. Good luck!!
Full story...
Hunter installed the washer & dryer before the door framing was put in.
If you want to put in the unit, you will need to make some surgical cuts on the door molding, and then restore.
If you are going to put this in, be sure you have a floor brace at the bottom, and top bracket as well.
If not, when you boat goes over on a heel, this can be a problem.
If you are installing a spendide, I hope you are handy with tools & troubleshooting.
These are not easy to repair. Fortunately, the US rep has a lovely guy on staff, and he’ll advise when necessary.
Lastly, think about using an exhaust fan. If you don’t do this, it takes days to dry towels.
Likes: hosemandc
Mikem
Dec 20, 2009
823
Full story...
Art, since my friend’s boat was on my dock I know for a fact it was not installed at the factory or by Hunter. Signature yachts of Seattle did the installation in the port aft cabin. As both you and I state, the door opening was enlarged and restored after installation. We bought our boat from Signature as well and they confirmed the process when we inquired about the installation.
Signature did an outstanding job and no trace of the “surgery” could be detected.
Jun 1, 2009
1,837
Hunter 49 toronto
Yes, I’m sure if this is done well, the door frame can look good as new.
Here is the issue....
As stated, make sure it is secured well. It is really important that the bottom woodwork (At floor level) is removable. On my boat, that was all but impossible, and was a full day’s job to modify the panel so that it could be taken out.
This is essential for 2 reasons.
If you need to service the unit, you will need to slide it out of the cupboard. With the lower wooden plate installed, this was basically impossible.
Much more importantly, (tell your friend about this !!!) the lower wooden piece covers the pump clean out. If you don’t drain this yearly, and take all the “Schmoo (Canadian term), out, the drain pump will seize up. This is a massive repair job.
What I did for this was install machine screw inserts into the wooden panel, and now there are easily removable bolts from under the floor. Takes 5 minutes to pull it now.
I mentioned an exhaust fan.
The fan inside the unit has limited pressure, and the hose run is long. If you install an inline blower, it will help quite a bit.
Make friends with someone who knows how to repair these. I had to change the flexible door gasket last year. It was myself & another very handy guy, and we went half out of our minds doing this.
As mentioned, the parts dealer has a really nice guy on staff that can advise you if/when you need help.
I’m not sure if you need to winterize your boat. If so, follow the directions really well.
Likes: hosemandc
