H410 Steerer
G
Gary Backway
Has anybody removed the output shaft from the pedestal housing on an h410 with an Edson 470 steering system. My question is, is there enough room between the lower housing and the cockpit sole to remove the output lever from the shaft so as to gain access to the lower bearing snap ring, or do you have to remove the centre cockpit console and raise the pedestal housing to give enough room to take off output lever? Gary
