H386 2003 Sealant around Skylights
Aug 4, 2013
12
Hunter 386 Comox
hi
One of my skylights is leaking - the black sealant is lifting a bit- is this a job anyone has done ? If so how and what sealant?
Thanks
Adam
BayMan
Sep 12, 2012
203
Hunter 450 Unspecified
I have used Life Seal. Comes in black or white. Tape both edges to prevent excess spreading and to get a nice finished edge.
BayMan
Sep 12, 2012
203
I did not because there was a healthy trough to put in the new caulk.
Sep 26, 2008
81
Hunter 44 Middle River, MD
I had a leak in mine. I choose to match the original sealant as much as possible so I would be assured that the new sealant would adhere to the original sealant. They original sealant was Dow 795 and I resealed mine with Dow 995 (better properties). I removed the trim on the inside window and added new sealant. Many places didn't have the sealant up against the fiberglass and the window, so I filled those voids. On the topsides, I taped off both sides and applied additional sealant on top of existing after cleaning it. No leaks since the application and it has withstood 50 mph winds with driven rain. Very satisfied. FYI... two person job with plenty of paper towels, cloth rags to clean-up as you go. The finished product looks like new.
