another thought
I was just thinking about what I wrote, and what I said certainly applies to the fuel tanks. However, thinking back, if you are only opening the water tank to put in a cleanout and can get by with a small hole (difficult to do the patching through, but probably possible) you can get away with the screw in type deck plates.You will have slight leaking if you pressure test it, but I still have them in my water tank. What I do is keep some silicone paste (the stuff you use on o-rings and such, try a scuba shop) and keep the seals lubricated. That way they tighten better and seal pretty well, good enough for the water tanks. The other advantage is you can quickly and easily get inside to clean, inspect, see how full they are (get the clear screw in part and you can usually just look) or even fill them from jugs, which can be a benefit in some places.
