E
Ed Schenck
What have you folks done about staysail sheeting? Do you still have the original setup or have you modified it? This past season I just cleated the sheet off at the staysail boom. I use it so infrequently because of the new and larger yankee. When I do sail with the staysail I just go forward and adjust. My original path was forward under the staysail boom to a turning block and over to the toerail. Then back to the aftmost starboard cleat through a series of blocks on the toerail.While in Sarasota last week I spied an H37C at Marina Jack's. That owner had moved his mainsheet into the cockpit as I have. He then moved the turning block forward of the mast and, with the same deck organizer, ran his staysail sheet back to the port cabin winch. Pretty slick.
