37c holding tank
I'd suggest you use the space under the shower seat for storage. Someone replaced the original holding tank in my boat with one about 2 ft long by 1 ft square, and I recently relocated this to the second compartment from the bow. It sits against the top of the compartment, and against the aft bulkhead. Naturally, there's some woodwork holding it up and securely in place. This compartment is also where the pump-out thru hull is located, and where the hand pump for the holding tank is located. It's a tight fit, but Everything fits in nicely, and there's still some room for shelves to store things that don't mind being close to holding tanks -- pumps, flares, boots, etc.
