E
Ed Schenck
We had summer on Lake Erie yesterday, 78 degrees and I played hooky. Finally cut that door on the inside of the aft cabin, it opened up a whole new world! Easy access to stuffing box, dipstick, strut mount, and hot water heater.Does anyone know if later H37C's had this as a standard feature? If you don't have one do it now. Here's how:The inside panel isn't fastened at the top, just wedged under the cockpit bottom. The forward edge, 31 1/2 inches from the aft bulkhead, has a seam that is covered with a vertical strip of teak, remove that. I put a keyhole saw in that seam and sawed straight up through the horizontal teak trim. Then I removed the bungs from that trim and two more at the aft end. After removing that trim and looking at it from both sides it was apparent how they put that in there. It had screws at the bottom from inside the engine compartment and at the aft tail piece. I removed the tank cover, that gave me a nice fiberglass ridge to use to guide the saber saw. I cut about 1/4 inch above the fiberglass from the front seam to within 1 inch of the aft bulkhead. Then that little six-inch vertical section at the back. I pushed it into the hold so that I could get a blade along the bottom to cut the sound deadener. Nothing to it.Now I'll add a small strip of teak under the cockpit to butt the panel up to. I'll secure the original trim around the sides and top but will have to add new at the bottom. The sides and bottom will overlap the existing panel, should be plenty secure. Not sure how to keep it in place, maybe a few screws. A friend tells me it is also helpful to make the aft bulkhead removable. It gives access to manual bilge pump and fuel tank filler and vent hoses. You can get to the aft cockpit lockers from your cabin!No more worrying about changing the oil, adjusting the packing, or winterizing the water system. A good day!Ed (schencked@bfusa.com)
