I removed the PSS stuffing box that came with my newly acquired boat because the rubber seemed to be too rigid and in need of a change. I decided to replace with a conventional stuffing box with 'dripless' packing (anyone need the rest of the PSS hardware? - new hose kit costs about $80).
When I came to install the new stuffing box I found that the four thru-hull bolts securing the shaft log extend past their nuts by a 1/4"
or so and are so tight on the outside of the stuffing box hose that they prevent installation of a hose clamp there. The result is that there is only about a clamp and a half length of shaft log to secure the hose to - not the recommended two.
I'm thinking I either have to cut at the nuts (tough for the lower two with shaft in) or remove and replace with shorter bolts.
Anyone dealt with this and/or have thoughts/advice?
