H36 Propeller shaft size.
Jul 7, 2004
25
Hunter 35 Augusta Sailing Club and Boca Chica
I think my 2006 H36 has a 1 inch shaft, but can’t find it in any spec sheets. I want to order a new propellers to be installed in two weeks. Can’t haul the boat for the measurements. Help!
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Pretty sure it is 1 inch diameter based on the stuffing box specifications on this site, which also sells replacement shafts. Might confirm with SBO. Also measure the circumference of the shaft with a string adjacent to the stuffing box and divide by 3.14.
  • Helpful
Likes: rgranger
Jul 7, 2004
8,502
Hunter 30T Cheney, KS
As mentioned, you can check it at the stuffing box with a caliper. No need to go swimming.
Feb 23, 2018
52
Hunter 356 Marseille
Measure the length of the taper and the size of the Key. I juste had a one off 3 pale manufactured for mine.
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
I'm sure you know by now but a Hunter 36 will have a 1" shaft diameter. And FYI- I would be extremely surprised if there weren't a whole bunch of hull cleaners in your neck of the woods capable and willing to do measurements or prop installs or whatever other underwater services you might need.
Likes: sail sfbay
