H340 fuel cutoff cable
Aug 19, 2018
7
Hunter 340 Camachee Cove Marina FL
I have a 2001 Hunter 340. I am trying to find the replacement part for the fuel cut off Cable. As mine was corroded and finally snapped. I see several online.I’m not sure if there is a certain length , etc. for this item. Any feedback would be much appreciated.
Levin
Apr 7, 2007
165
Hunter 340 San Diego
Sand,
I'm in the process of doing this right now. Has been a bit of a pain. The line appears to be about 13' long and the orginal on mine was a Morse cable. You can't find this cable anymore and the next closest replacement is a Teleflex utility cable. You want the "hub" version of this rather than the "no hub" version (don't ask how I know this or how much shipping was back to where I bought it). You also will need an adapter to attach the line to your Yanmar engine. Luckily they sell all of this here at the SBO shop. Just buy it there... save you a lot of headaches. I'm sure the cable they sell you is in fact a Teleflex "hub" one.
Take care,
-Levin
Aug 19, 2018
7
Thank you !! This helps ... I am an emergency tiller away from being up and running !!!
