Derek Rowell
I just had the stuffing box/coupling hose replaced on my H34. Here's the problem (that's making me very nervous):Thel ID on the original hose was 1 5/8 in and the shaft log and the stuffing box are also 1 5/8. The new one that they installed uses 1 3/4 in. ID hose. The yard simply clamped the hose down on to the shaft log (bronze) at the stern. The extra 1/8 in diameter in that stiff coupling hose requires a lot of tension in the hose clamps to compress and hold it. I'm concerned at the posibility of it coming off - disastrous!The yard says that nobody makes a 1 5/8 in stuffing box for a 1 in prop shaft. I'm not sure I believe them - certainly they made them in 1983! Does anybody know where I can get the correct size for the H34? I'll replace it at the next haulout if I can find the correct unit.Derek
