E
Ed
I am going to install refrigeration conversion in my 8 cu. ft. icebox. Is there any reason other than power consumption that I should not use the larger Cold Machine (for up to 15 cu ft) in order to get faster cool-down, larger freezer volume? Also, West Marine says that the Super Cold machine cooling water pump should only be turned on when the boat is under way. Does that mean that the unit is in the air cool mode at the dock when the pump is not on? can the unit be installed without the water cooling kit with the idea of installing it later if the boat is moved to warmer climate?
